I'm having trouble with compression. The right side is low (70) with 10 cranks compared to the left (105). I'm at 3000ft elev. The left side runs, the right side won't.
Timings OK.
Sparks OK.
I've replace rings and had valves ground.
New head gasket.
When I put it together this last (THIRD) time, I checked the compression on the left with it running just on the left cylinder.
Idle(1500-3000 rpm) 70 psi
3000-6000 rpm it goes up to 110 psi
above 6000 rpm it drops down to 70 again.
So, what are your thoughts? Sticking valve? Warped head?
I can now take the engine out, get down to the pistons, back together in 6 hours....I'm not sure this is a skill I want to hone.
Timings OK.
Sparks OK.
New head gasket.
