Hi All, I am trying to increase front suspension preload by just a little bit so I played with it and now I want to start over by returning it back to default first, but here is a thing I cannot understand if I am doing something wrong or this is normal.
User manual said: "The standard position is 3/8 in (9 mm) from the adjuster top surface to the fork bolt top surface." I did exactly that and direction of the slots on the screws is different on both sides, for example left screw is at 12 o'clock and and right is at 3 o'clock. Both measuring exactly 9mm. My guess that this is normal, but I am a bit concerned because when I took brand new bike from dealer both screws were at 12 o'clock, so I am not sure if I am doing something wrong or dealer had it mismatching a little bit?
Thank you in advance for any help.
