Have a gas tank with rust on the inside. Ive read of things to buy that when flushed around a couple of times, creates a protective/plastic coating on in the inside. What is this, where can it be purchased?
Be careful the bbs can get stuck very easy in the tight spots in the tank and they don't clean as well as nuts or bolts because of the sharper edges they have.I've got a Cl200 that has kreem in the tank that is falling off. I'm thinking about using acid to clean it.I'm going to protect the outer paint. Then use BB's or small nuts to get the larger rust off.
I might use the electrolysis method afterward. It just gets the smaller particles, right?
Would it be better to coat it again with por 15 or just leave it uncoated and full? Thanks in advance.
