Need your help guys!
I am having trouble with my Triumph 2006 Sprint ST 1050. It does not want to start using the starter switch on the handle bars. If I use my by pass switch that I made and connected to the starter solenoid, I can start the bike without any problems!
I have already replaced the starter relay and starter solenoid. The battery was on my list to replace since it is about four years old. So, I did replace the battery just for your information. The starter works fine since the bike will start using my by pass switch. I have checked all the fuses and all tested OK.
I opened up the starter switch on the bars and it looks fine, no broken wires or corrision. When I turn on the ignition switch the instruments power up, no problem. Th eengine kill switch is working fine. If the bike is running and I engage the kill switch it kills the engine. If I start the bike and put it in gear and lower the side stand the engine will shut off too.
So, I am getting frustrated trying to locate the problem. Please help me.
Thanks, Mike
Thanks, Mike
