Suzuki Bandit Wont Start
9K views 5 replies 4 participants last post by  einwod
#1 ·
Hey all,
I know that this is a very difficult thing to try and troubleshoot over the web, but I figured I would take a shot. I have a 1993 Suzuki bandit and it wont start. The starter engine turns but there is no catching of the engine. It's not like it stalls out, or does a few strokes and then stops... It doesn't do anything, the starter just turns.
The bike was running fine 2 days ago, aside from some difficulty starting it (the starter would have to turn for a while before the engine would catch and start) and to my knowledge nothing has changed. Once running it would stay running (so I doubt it's a bad spark plug/timings on the cylinders firing.)
So far I have tried the following:
1) Checking for loose spark plug connections
2) Made sure fuel was reaching the carburetor
3) Charging the battery/starting it with the battery attached
4) Rolling the bike to the top of a big hill and attempting to jump start it using the clutch (It just did a few cycles and stopped... Didn't sound like it was running)
5) Putting fresh gas in
Any ideas would be awesome. I really don't want to have to take it to a mechanic as I am looking to sell it and what I would pay would probably be about 10% of what the bike is worth....
Thanks!
#3 ·
Thanks for the idea, but after paging through the manual I don't think it's either of those things. If the kill switch is off, the starter motor wont turn. Same with the fuse - the fuse responsible for ignition is also responsible for the starter motor. Since the starter motor is turning, I dont think it's either of those things.
I really appreciate the help though. Any other ideas?
#4 ·
Just an update; I decided to take out the spark plugs to make sure that I was in fact getting spark. I am. The carburetor also has a fuel drainage valve which I removed to make sure that fuel was in fact getting to the carburetor - it is.
Any ideas guys? As I said, I really appreciate the help.
