Hey everyone, I ride a 98 Suzuki VZ800. My question to you is, how often do you downshift into first gear? More specifically, do you ever downshift into first gear around sharp corners going 10-20 mph??
Personally, I would shift in the turn if that was the case. If I take a long left turn across several lanes, I will often shift to second near the end of the turn. I'm usually well out of a right hand turn and upright before I have to shift into second.My normal downshift point to first is about 10 MPH, I upshift to second at around 20 MPH. Many sharp turns put me between those speeds and I am still trying to figure out which is a better gear for me and my ride. If I roll through in second I am at 1500 RPM or less coming out of the turn, far from ideal. On the other hand, I don't like to be pushing the top of first gear as I exit a turn.
