Hi Guys.
I'm not a great mechanic but I have been fiddling with small repairs from time to time, however now I have encountered a problem that I simply have no answer to.
The next step is to take it to a mechanic, but since its an old bike (1992) and lots of parts in need of changing, this could be a costly affair. Also, I still don't know what's wrong and I can't readily transport it since it won't run. I hope you guys might be able to help me out, as I gather that it might be an easy diagnostic if you know your way around a motorcycle engine.
So, here is the problem:
Here is what I have tried so far in response:
(- Changing air filter - not in response, as it was done before the problem occurred. See above description)
I will be grateful for any help, as I am pretty clueless at this point, and also almost flat out broke!
Please let me know if I can provide you with additional information that might help to clear up the problem - including photo/video/sound.
Sincerely
Frederik
- Will only start-up using the choker which can then be stepped down once it has run for a few minutes
- Engine stalls out when opening the throttle, even a little bit will stall out the engine completely if I don't close it again. This happens with and without choker
- Exhaust air comes out without much smoke and warms up when the engine runs idle. Nothing notable to report as far as I can tell
- Removing gas filter
- Checking gas flow through the tank and through the petcock valve
- Running the engine with open gas tank
- Changing spark-plugs
- Checking gas flow through the carbs
- Checking for vacuum leaks in the carbs
- Adding ethanol to the gas tank
Sincerely
Frederik
