Battery/Electrical issue....help please!!!!
1 reading
2.6K views 3 replies 4 participants last post by  Williamdcollins
#1 ·
Hi,
I have an 06 Kawasaki ZZR, and I rode it one night with zero problems, but the next day when I went to start it up, I turned the key, and non of the electronics, lights, or gauges worked...I had no power at all...It acted like the battery was completely dead... It didn't even click or try to turn over....I had nothing...I then jumped my bike and the electronics/gauges/lights all worked and I barely got it to start, but it ran very poorly...as soon as I took off the jumper cables it immediately died...I figure it's the battery, but I found it very strange that it was fine the night before, and the next day it was completely dead...Just wondering if any one else had any insight as to any other problem
this could be, or if it's just a bad battery... Thanks!
#3 ·
VERY easy to test a battery: put it on a trickle charger for a couple of days. Then, put a voltmeter on it, disconnect the spark plugs, and spin the starter. If the batt voltage goes lower than 9V during starter cranking, the battery needs to be replaced.
