new stator and rectifier, it was starting before but it would die from battery not being recharged, now i replaced both, battery is fully charged and won't start but turns over, there's plenty of gas to, what could this be
Let's keep everything in same thread for logical flow. We may need to refer back to earlier posts.bike would start up but die cause it needed a stator and rectifier, now it won't turn over, i got two codes from the bike c28 c46 how is this even possible..
only thing i had to unplug was the fuel injectors to unscrew the clamps for the airbox but there back on 100%, i looked at the valves, there was a secondary throttle valve delete, so guessing that's why there's a code so less worried nowLet's keep everything in same thread for logical flow. We may need to refer back to earlier posts.bike would start up but die cause it needed a stator and rectifier, now it won't turn over, i got two codes from the bike c28 c46 how is this even possible..
Many, many components are interconnected on bike. Just disconnecting and reconnecting battery can generate surges and sparks which can zap sensors and wiring. Just lifting and lowering tank can yank on vacuum hoses and wiring. Extremely common on CBRs to yank and disconnect MAP sensor's vacuum hose with right-hand when lowering tank. That's why I always do it left-handed while standing on left side of bike.
In your case, threading through wiring for new stator and RR can easily have pulled on some other wiring. EFI system uses extremely fine wiring and small connectors to carry tiny signals. Additionally, many components share similar plugs that can be cross-connected improperly. For example, the CMP (cam) sensor uses similar connector to STP sensor and can get mixed up. Or the AP sensor vs. TP sensor. Did you have to disconnect & reconnect any other plugs other than stator and RR connectors?
Welcome to The Forum, do you have spark?
i don't see how the spark plugs could go bad or anything, what else could it be?
But,
Does it have spark?
Check for actual spark at plugs.
i'm starting to think it's the stator
First Test:
Does It Have Spark? (Important Need-to-Know)
4. Do you have spark? What colour?
Go ahead. Check for spark. (Seems some of us are kinda stuck on that)there's half a tank ๐คฃ
OP needs to answer this question instead of dwelling on the statorGo ahead. Check for spark. (Seems some of us are kinda stuck on that)
Not the stator.
The stator is only a part of the charging system. It's only function is .......
No, stator has nothing to do with starting bike
...... instead of dwelling on the stator
Nois there a possibility this is from the cheap ebay stator? $30 unbranded i know you said it doesn't have anything to do with it but online it says a faulty stator will cause no spark i'm just so confused
no no nodo this test of charging system. Post the .........
