1 - 2 of 2 Posts
Hi guys, just replaced cylinder and piston and its the same problem of leaking oil from breathing tube. Does anyone had same problem or know how to fix it?
The crankcase breather, which probably exits the head near the valves? There is always an oil spray, even if there is an oil/vapor separator inside the head. That is why there is usually also an oil drain on the air cleaner, below where the tube connects. If it's more than an occasional drip, more like a squirt or flow, you have something holding oil near the vent, where the breather tube attaches, or too much oil in the system.
1 - 2 of 2 Posts
