Yamaha Vino 125 Brake Disc no longer distributed in US !?
3 reading
21 views 4 replies 3 participants last post by  Jack Klarich
#1 ·
I just went to order a replacement OEM brake disc for my Yamaha Vino 125 (OEM part# 3UH-F582U-00-00) and they are out of stock a parts places everywhere. The only places that claim to have it are selling it for close to $200. I bought a real OEM original one in the past once for ~$70.
I did find a "seller" on Amazon that sells a replacement brake disc by a manufacturer called Lang-Ya Int. that claims to be compatible- but in their product photos the disc is clearly stamped "180x48x3mm". The OEM specs for the rotor are 4mm thick with a minimum of 3.5mm allowed before replacement is required.
Anyone know of a reasonably priced good replacement disc for a Yamaha Vino 125 (YJ125) ?
#2 ·
Unfortunately, as parts for older bikes get used up, prices increase. I've had good luck with this outfit for rare parts.
Reactions: cruiserandmax
#3 ·
Thanks- that site is a great resource- bookmarked!! I just found a salvage real OEM one on ebay that had clearly been sitting a lot- a bunch of rust- but nothing actual brake use won't get rid of, and it's still basically at 4mm- for $40.. But yeah- I feel like I I could keep this scooter running almost forever as long as I can keep getting reasonably priced parts..
I messaged the seller of the aftermarket "new" one with the 3mm stamp, and they said 3mm was the min service limit, and the rotor itself is 3.8mm- both numbers below official Yamaha specs :(.. Salvage or NOS from sources like that ^^ from here on out I guess for the parts that are no longer sold.. Thankfully a lot of basic ones still are!
#4 · (Edited)
In addition to thickness numbers, you'll want to gather info on materials used. Factory part tend to be cast-iron or steel. Aftermarket part may be 420 stainless and much stronger. If so, it can be quite usable down to 3mm and last twice as long before getting there.
I replaced factory discs on my Ninja and CBR racebikes after they wore out in 2-3 yrs with Galfer 420 versions. They're both over 10-yrs now and on their 3-4th set of pads. Holds up much better against more aggressive sintered semi-metallic pads compared to factory discs.
Reactions: Jack Klarich
