I have a 2003 Yamaha R6 with 27,000 miles.
Changed my oil (only 2 quarts. I messed up), road it twice (less than 5 miles each time) until I realized it needs more oil. Road it two more times after that without issue. I used STP 10W-40. (Manual says this should be good)
Just lubed my clutch with WD-40 last night and that solved my stiff clutch.
Tonight it backfires for the first time since I bought it.
It is suddenly MUCH slower to accelerate in 1st and 2nd gear now.
If it hits 4k+ RPM in 2nd gear, it backfires and does not accelerate much. If it hits 5k+ RPM in 3rd gear, same thing. No issues after 4th gear.
What is going on? Solution?
Any help is appreciated. Thank You.
Update: I put seafoam in the gas tank, let it run for 5 minutes and I could hear the engine occasionally make odd noises like the carburetor was cleaned (or whatever else was causing the issue. IMMEDIATELY, was able to rev up to 5k rpm in first gear without a problem.
Drove it 5 miles to Costco for Premium gas. It did jump the accelerate a bit in 1st gear (similar to above), but no other issues. Barely noticed the problem on the ride back, so I assume it will be solved soon, or I'll just add more seafoam once tank is lower.
Appreciate all the help!
