Hey guys i have a 01 yamaha roadstar
I try to start it an it want start... It cranks a couple times an clicks... I took the starter in an its fine... Replaced the starter relay an thought it was the battery so i hooked it up to my car battery.... Nothing :( please help
Check the voltage on the battery. Check to make sure the battery connections are snug with no slop. Have the battery load tested. Check to make sure the starter connections are snug. Make sure the battery ground is snug and not corroded.
Ghost in the machine
Sounds like a bad battery. Do a voltage test on the battery, and another voltage test while pushing the starter button. Standing voltage shouldn't be less than 12.5, cranking shouldn't be less than 9.5.
