1 - 8 of 8 Posts
I have an 81 Honda Cm400e that wont start. When I hit the started button, my solenoid clicks. I so know my starter button and my solenoid are good, right? Dead battery is what your thinking, So i touch my starter cable to the battery and the bike starts right up. So I know my battery is good. What am i missing?
a loose connection or bad relay
+1, check all connections and clean the main grounds.
Also, the actual contact bar within the solenoid can corrode and do exactly what you're describing. Sounds like the solenoid is working, but it's not making a good contact. Some can be carefully taken apart and cleaned. Otherwise replace it.
Do verify the other stuff first though - it's a pretty rare failure.
went to the honda dealer, told him what was going on. he sold me a new solenoid...this time it worked. guess the one i bought was junk
Thanks for the help wadenelson and everyone else ....Ill keep this in mind for next time....Now where do I get that blinker fluid you mentioned?
1 - 8 of 8 Posts
