1 - 12 of 12 Posts
I have to say, I'm a bit disappointed by this Clymer maintenance guide that I bought. For instance, it describes very well what I have to do to change the oil and the oil filter, but it doesn't tell me what kind of oil filter I should use. I could go with what's there already, but planes have been known to have life-threatening emergencies based on that kind of maintenance.
My bike is a 1983 Honda VT500 (why can't we have sigs, so I don't have to write that out each time?)
Banned
Go to your Honda shop and buy an oil filter. The friendly parts person will be glad to look up the exact filter you need.
Avoid Fram; pick up a Wix. If you don't have a MC shop nearby your local parts house can order them for you. Or you can order on-line - get enough for a year.
Well the link Custom gave me recommends Purolator, Mobil, or Supertech. It lists WIX as available but not recommended.
I'm not sure what they use to classify the recommended ones. There may be slight differences in the filtering, but none of them will actually hurt your bike to use them in my opinion. If you keep the oil and filter changed at the proper intervals, your bike will last a long, long time.
I don't have first hand experience with this, but I have heard that the filter element in a Fram can collapse and block oil holes in the metal casing. This is not good if it happens when installed on your bike.
That's the word.
To answer this question, we had problems with people abusing them, so we cut them out (at least for now). If you want, I believe you can change your "title" (that appears under your avatar - "Member, Junior Member, etc."). You can just put your bike there if you want. I think that you can do this from your User CP link up at the top left of your screen.
As far as filters, I say Wix, but that is just my opinion (I am luck and have a reusable centrifugal filter :cool: )
Mike
Very Famous Person
The best filtration would be with Amsoil nanofiber filters. They filter finer than ANY other brand/type.
RonK
1 - 12 of 12 Posts
