I have a 2002 Honda CBR954RR. It has 2,209 miles on it. I put 10 of those miles on it test riding last couple days. Here's my problem. The Bike was, has not been ran since 2006. I changed the fuel pump, spark plugs, oil, oil filter, front brakes, air filter and topped it off with a new battery. when I drained the oil it had fuel mixed into it, probably from the gas that sat in it all that time. after installing fuel pump the bike started right up. sounded crappy running. I gave it a test ride and it was responding at first now the power is low. I'm leaking gas from where the pipes meet the engine. you can smell the gas it's running so rich. Now I don't think it's a head gasket as my coolant is fine there is no white smoke. but after speaking to local mechanic I found out my pipes aren't all hot. after cleaning fuel injectors myself and changing the oil again along with another pair of new spark plugs. I managed to get one of the two pipes hot, the other was still Lukewarm. after shutting bike off then on again. both cylinders stay cold again. the bike is idling crappy. Do I need my injectors professionaly cleaned, or is it something else. The biggest thing Ive noticed is that during those test rides I've put in two fuel tanks of gas and got 11 miles she's empty right now because I don't wanna change the oil again. what would cause your bike to run that rich? and everybody says compression test. ok and if it comes back fine then what is the problem. if it comes back low what is the problem. I'm trying to figure out if its something I can afford to fix seeing as Invested all the money on purchasing the bike. some body said power band. is that a possibility?
