Leaking extremely slow but it's leaking.
It's located under the under the seat (most front of it) it's the gold box I'm referring too and yeah looks like it's connected to the gas tankHard to tell by the photo, and not knowing what bike or where it is located. But my guess is that it is a fuel gauge sending unit.
Thanks Hun,OP has an Icebear PMZ125. Based on some GY6 and Icebear part searches, that's the fuel level sender. Since you bought it new, the dealership should be able to get you a new one under warranty.![]()
You may not have allowed the gasket stuff to properly cure. And you've not indicated exactly where it's leaking. Around one of the screw/holes or near the center. It might take that new unit to fix it or you might need some gasket material and make a gasket then put the gasket putty on both sides of the new gasket you made then let it cure some(24 hrs?) before adding fuel. I'm thinking right now that you just didn't let the stuff cure long enough before putting the weight of the fuel back in or it's leaking somewhere other than the screw holes. Would be nice to know these details. It's not a good idea to remove it though. Just looking at it, that could be 5 holes you'd have to plug but would also be a waste of function. People complain that they don't have a fuel gauge all the time. The next owner would cuss you to no end.:crying: Not that you'd care.:angel:Okay well, drained the gas. Removed the fuel sending unit.. There was no gasket? Put some gasket maker puddy stuff on it, put it back on, made sure it was nice and snug. Let it dry for a few hours and added gas back and still leaking... so..? What does this even do? Just makes my fuel gauge read how much gas is in it? I see two wires connected. If this is the only purpose of it, I can just plug the hole entirely in theory and say screw it and let it read empty/full all the time. Unless it's somehow telling my engine/carb how much fuel to flow? Anyone know the science of it or thoughts?
Honestly I'm still not 100% sure what that thing even is. Fuel level sensors in Chinese bikes are usually plastic units passing through a metal bracket. Yours has the metal bracket but it doesn't have the gaping hole with the sensor passing through it.Okay well, drained the gas. Removed the fuel sending unit.. There was no gasket? Put some gasket maker puddy stuff on it, put it back on, made sure it was nice and snug. Let it dry for a few hours and added gas back and still leaking... so..? What does this even do? Just makes my fuel gauge read how much gas is in it? I see two wires connected. If this is the only purpose of it, I can just plug the hole entirely in theory and say screw it and let it read empty/full all the time. Unless it's somehow telling my engine/carb how much fuel to flow? Anyone know the science of it or thoughts?
No reason to be upset friend, people here have only the information given (or not given), and beyond that we can only speculate.You guys get fiesty lol I did say what the problem was, I said I took it to get looked at and they said it's the gasket causing the leak.. but, there wasn't a gasket period. So I bought gasket maker, let it sit til "tacky" and put it back on, and allowed it to cure for 7hrs which it only said 6 on the package. Then added fuel back, the leak contuined. And how the hell would I mess up the warranty by taking 4 simple bolts off and adding gasket maker. I don't have two weeks to wait for the part to ride. This is my main source of transportation so of course I'm going to see what I can do to fix it in the meantime. And this bike was shipped to me, no local dealership. Warranty simply covers parts, I do the work.
Good to note for if/when I buy a new Chinese bike! I didn't know that!And this bike was shipped to me, no local dealership. Warranty simply covers parts, I do the work.
