1 - 20 of 111 Posts
Banned
Have appointment at the Harley store for my ElectraGlide tomorrow, recall about the brake fluid.
Just so happens I ordered owners manual at the same time I was checking on recall
I'm living right, Friday my owners manual came in.
EG has been in tent, so I switched it with the dyna that has been my jump on and go bike
Well I had EG out, it's 57*, might as well use some gas so I'll be closer to empty when I get to the big city where 93 is 65cents a gal cheaper
So I went out to ride the ridge, very different than on the dyna or crotch rocket, but I was happy with it's handling, first time I've had that bike on the ridge
I had noticed on the left grip, the end had a on/off symbol and numbers, I thought that might be heated grips
Halfway through I remember the grip and the heated seat and turned them both on.
After a few minutes my butt didn't have a chill, I never felt heat coming through my pants
My hands did the same but eventually I felt heat coming through my deerskin work gloves
Got to my brothers, took gloves off and felt grips.....pretty warm
I rank heated grips and seat way up there, that was nice
I had this little windshield extension that I put on the C90T, cut the wind noise down so much I could hear the stock pipes......when I traded it in I took the extension off, today I put it on the EG, it is a perfect fit, the windshield is about chin level, the extension adjusted down is at nose level......on the C90T it was too high
I had Jimi on the cd, I could hear it planly without cranking the volume way up.
The FLUID????
I know they have hydraulic brake problems but this would be the first about fluid I've heard. You sure it's a fluid problem? That would affect cars as well I'd think. That would be a major recall.
Banned
The FLUID????
Harley uses their own DOT 5 its probably causing corrosion or something.
Heated seats and grips? Humbug.
I've got that same gadget on my EG's left hand grip. One day last year I was out riding and started fiddling with it. After a few minutes I figured it just wasn't working. A little while later, after I had forgot about it, both grips seemed to be getting uncomfortably hot, they worked! Didn't notice the seat getting any warmer though. Didn't know it was supposed to.
Banned
Discussion Starter · #6 ·
The recall is for touring models only with ABS, the fluid(dot4) somehow retains atmospheric moisture and needs to be changed every 2yrs......this recall is a recent recall because some brakes have locked up while riding
The first change of fluid is on the house, now every 2yrs it's on me
I suspect the moisture makes its way in thru the ABS, my Dyna is dot4 non-ABS and no recall
Banned
Discussion Starter · #7 ·
I've got that same gadget on my EG's left hand grip. One day last year I was out riding and started fiddling with it. After a few minutes I figured it just wasn't working. A little while later, after I had forgot about it, both grips seemed to be getting uncomfortably hot, they worked! Didn't notice the seat getting any warmer though. Didn't know it was supposed toTe
The thingy on grip only controls grip heat, my seat has 2 switches for heat...1 for me, 1 for wife
Brake fluid is hygroscopic it absorbs water right out of the atmosphere or anywhere else,
your brake reservoir is required to be vented, ever wonder why there is a rubber bladder between your glycol based brake fluid in the reservoir and the air space above it :/ that is to reduce the exposure to atmospheric moisture, ever see water droplets on top of that bladder, that is water from condensation get it out of there.
Dot 5 is silicone based and silicone does not absorb water, but water can still get into a hydraulic system other ways.
Banned
Discussion Starter · #9 ·
Went to the big city Harley store. Last WK my phone said it would 70* today.....it was wrong
Couple other things I wanted to check on while there......backrest for me
There's 2 types of brackets for backrest, my bike has the cheap one which requires the expensive backrest
I tried one, me and mechanic couldn't get it to lock in, one pin that locks in was bent. Got another and I thought I got it locked in, tried it, went and paid for it(forgot the other thing I wanted to get), half way home it came loose.
Got home, discovered while trying to get it into the bracket I had worked the spring loose. Instead of trying to work thru that hole in the seat I unstrapped the seat, got on right side, opened saddle bag and raising the seat just a little I could see what I was doing and get my hands to it.........went in and locked, very easy when you can see what you're doing
Mine being the cheap bracket, in order to adjust it forward or back, there is 4 mounting holes on each side, so you have to take it off and remount it to make adjustment.......the expensive bracket bolts in, run a cable and switch out from under left front of seat.....pull switch, move backrest where you want it, let go of switch......this setup would have cost $350, but since I already had the cheap bracket, the backrest cost me $200
I hit the interstate and went to set cruise....oh man I forgot I needed the button cap for the set/resume switch
Man-O-War hd had already replaced it no charge, and they washed my bike while they had it
Sitting at home waiting for wife to get home so I can head out on the Dyna
Banned
Discussion Starter · #12 ·
I forgot yesterday the Harley store also washed my bike for free
Today I went insurance comparing, my Harleys were at progressive which beat the **** out of State Farm, I had full coverage minus collision and medical, both $285/yr
My crotch rocket at Farm Bureau, full coverage minus medical...I owe on this one......$95/yr
It went there because progressive wanted $450/yr for GSX-S750Z ABS
I went to Farm Bureau to check......now both Harleys are full coverage minus medical....collision included + I got medical for passenger ($4.50 each bike/yr), I doubt I'll have a passenger without medical, but just in case, I won't have any passenger on the crotch rocket. Total both Harleys $220/yr
Got all that done
Then took the dyna for ride around the ridge, it was nice today, once on the ridge didn't see a single car, got to 504 and there was a car turned in before me, he ran good pace, got to passing zone he slowed down, on up the road I came up on a UPS van, behind him about half mile and he turned off
Only saw one bike and that was after I got back into town
On The Road Again!
It was a BEEUUUTIFUL day here today.
So my buddy and I played hooky and hit the road for a while.
Not a cloud in the sky, 65 degrees, so we headed out on big
loop through the back roads of northwestern New Jersey.
The best part was following roads we'd never ridden before.
Didn't know where we were going but the roads were so nice
that we didn't care!
Of course we had to stop for ice cream.
(can't have a bike ride without ice cream)
Put on just about 100 miles by the time we got home.
Only a short ride, but it was a good one.
Banned
Discussion Starter · #14 ·
Got my second shot, feeling a little chilled in the house, decided to go for a ride
Got out to 45mph zone and freezing to death, appropriately dressed for 60*, stopped at brothers to warm up, rode home(8miles) total
Banned
Discussion Starter · #15 ·
Got some stuff done today, worn out, and the text comes in
Just about an HR ride with my buddy, both shoulders about to fall off, still a little on recovery, muscles drained after couple hrs of mild work
We hit the curves, I think he was seeing if he could get away from me...... that's good to try every now and then..... I try sometimes to get away from my cousin......not ever going to happen
Banned
Discussion Starter · #16 ·
Yesterday 70's, after getting a few things done(not all), adjusted chain on crotch rocket, then took it out, been awhile.
This thing gets funner everytime I ride it. Went out the ridge and back 504. Going out I was flying(for me) until approaching the horseshoe that, if you got the balls, can be done on a dyna at 60, but I came upon a suv and got to do a blistering 30, got thru the curve and halfway through the next is a dump truck, down to 20, wee little bit of a straight and I passed the car, after a couple more wasted curves we do a right, with an immediate left and I can see .1m ahead....... I'm gone
Back on 504, it's way longer, got plenty of curves, but actually has some passing zones.....it's not as famous because it is call 504 not something cool like Brown Ridge. It is less traveled and just got repaved
504 had no traffic, except me too much fun.
Got back, picked up this winters mess of limbs, and mowed for the first time this yr.
Today it's snowing
That horseshoe on the ridge, I've got the balls to do 50 on the inside lane(on my dyna), the outside best is 45, if you go off the outside it's going to be a horrible death.
Banned
Discussion Starter · #17 ·
One day Dyna wouldn't start so I rode the crotch rocket for a quicky around the ridge. After getting back tightened neg terminal and took dyna around the lake, found a new man made road hazard, a traffic circle, in an area where the people don't understand the use of a 4way stop.
Today, I was going to take friend out the ridge, he's never been, had to go a round about way to get there, once there he chickened out.
Secret Agent
I hate roundabouts... Most of the ones around here we're installed where there was only a two way stop because the highway was the throughway. Now the highway gets to dance too. Of course they don't highlight the inner curbing, so when it's dark and raining, good luck seeing it
Roundabouts are great if you know how to use them. It's all about timing.
Banned
Discussion Starter · #20 ·
In the beginning it was 2way stop, then because of no accidents and no traffic backups "they" decided it needed to be a 4way.......that was many years ago. Still no accidents, backups only last till somebody goes.....people like to sit and look at each other. So "they" decided it should be a traffic circle.
I don't think a semi can make 3/4 circle(left turn) because it is a tight circle
1 - 20 of 111 Posts
