What did you do with your bike today?
893703 Views 12256 Replies 560 Participants Last post by  gunsmoker
Me and my lady went for a nice ride on the Street Glide to a nice restaurant in Evansville, Ind. It has been a beautiful day.
Reactions: 5
5321 - 5340 of 12257 Posts
Took my VN900 to a friend who changed out the front pulley to a Baron 34 tooth. Not quite as straight-forward as expected but after removing the rear mud guard from under the fender, loosening the belt a smidge more than initially, and riding 50 miles back to the house it seems to be fine. The ride at 70-75 is smoother now, and didn't look for sixth gear nearly as often :)
I am sorry for your loss. My wife passed away after
twenty years, Maybe the funeral parlor has a support
group? or you might just feel better out on the road,
your knees in the breeze and remembering the good
times. You don't want to get over it, you want to know
how to to get along with it.
I like Harley a lot , got an old 91 Snorty1200 that I put
a fair amount of work into. The Guys at ThunderBay
in Tampa did a great job and later I got a Wide Glide
but sometimes I think the older the bike is, the better
built it is.
God bless and take care
Time was coming up for an oil change on the wide glide
so I went out and got the 3 qts, a filter and an 'O' ring for
drain plug. Then I took her out, for a short ride to get
oil hot so it would all flow out of drain. Came back and did
the oil change, put tools away and went into the house for
a few cold beers. Nuther few days I'll change primary and
tranny fluids and mark down mileage for said maint.
Put the stock mufflers back on my Indian. After getting rid of the catalytic converter it was just too loud. I can't tell any difference in performance but much better sound-wise. I'm sure others would like how loud it got but I sure don't. Already only have one good ear to hear things with. Got to take that into consideration. Really can't afford losing anymore hearing. But I liked the looks of the more open mufflers but that hearing has to be saved.
Larry, it's been my experience that 'Harley owners,' have rafters full of exhaust systems they've tried, not to mention the stock pipes up there too.
My besy system was a 'Thunderheader,' a two into one pipe that made my very high performance big twin Harley sound like a 'small block' breathed on 327 with headers:grin: The sound when the bike came on the cam was enough to make me wanna cry it was so beautiful:crying: The end of the exhaust was far enough back that it wasn't loud at cruise speed and it didn't 'drone,' like some systems.
https://www.google.com/url?sa=t&rct...24.htm&usg=AFQjCNHLQlr40-bXq9nHNlKC4t-FpWqhbA
Sam:nerd:
Thunder Headers are the Ne Plus Ultra of V-twin exhausts.
Expensive, but if you're serious about building an engine they're the only way to go.
Oh yeah, Thunder headers rock.
Hello Porky,
Last week I was looking at some Vance Hines pipes,
rather large sweeping pipes, slanting downwards and
outwards in Chrome and black, I don't think I need a
stage 1 for this if I don't change the air cleaner, but if
I do change air cleaner I am told I'd have to get fuel
system remapped as there would be more air sucked
in and without remapping, fuel mixture would be lean.
What do you know about this? and Thanks very much.
The Snortster
Hey Ray, I know that 'EYE' has been reading and responding and he's the one that knows a LOT about Harley's, so we'll just wait for his ideas:grin:
Sam:nerd:
Thanks! I have the 'Tommyguns' but thought it would be neat to change
the looks every now and then . I found out NEV'R DULL does a great job
on chrome pipes, I buff'em out after with an old H-D T-shirt.
Have a good day!
In his 'profile,' it says the Sporty is a 1991, so it's got a single Keihn 40mm CV carb which can be jetted to perfection:grin:
Sam:wink2:
Hello Eye_ M_ No_ angel Ray here, was thinking about getting big radius
Vance Hines pipes, not for the Snortster but the 2015 wide glide, someone
said, due to bigger pipes, would have to get engine tuned due to back
pressure? If I got a bigger air cleaner, fuel system would have to be
so-called mapped out to allow more fuel otherwise engine would run lean,
sounds right. I like the look of those big radius pipes and was told they'd
sound deep an rumbling, what do you think? and Thanks very much.
WHOOOPS guess I 4got to say, the bigger pipes R 4 the wide glide!
Hey Ray, what'd'ya say?
Your 2015 FXD has wide band O2 sensors and an ECM that is capable of doing some "self learning," so it may be able to handle the new pipes and air cleaner without any further changes. The difference is in exactly how much air the new cleaner is letting in, and how much exhaust the new pipes are letting out. On some air cleaners the actual element really doesn't allow a lot more air to enter. That can especially be true for units that are designed more for looks than performance. In that case you might not need to do anything further. On the other hand, if you have a really free flowing filter and pipes that evacuate very well, you still might need to re-map your ECM or add a fuel controller. You'll need a flow bench or a chassis dynamometer to determine exactly what your new set-up is flowing, or be willing to pay someone else who does have them. $$$$.
What you might want to do instead is to put on your pipes and air cleaner, put in a brand new set of fresh plugs, and ride the bike hard for a hundred miles or so. As much highway speeds as you can. Then pull your plugs and read them and see if it is running thin, very thin, or if it's running pretty well. Once you know that you can assess whether you want to have the ECM re-flashed or if you want to add a fuel controller or what. You may find that you don't need to spend another 3-400 clams at all.
Thanks very much Eye_M_No_Angel,
Frankly was not or am planning on a new air cleaner, as I am told
that doing so ( if new air cleaner element is larger) The bike would
require being tuned as more air coming in would make air/fuel
mixture leaner which can cause overheating. I just think getting
different pipes on her would look good at times.
The 91 Snortster is doing very well I changed over the rear direction
signals to running lights/Direction signals. went to NAPA and got the
socket insert w/ two contacts, low filament is running/ hi side is direction
signals, that + regular tail-lite gives more notice of a bike at nite if just
using tail lite and that bulb's low side went out.
Thanks for your help.
In that case just bolt on the tubes and you're good to go.
I'd still put in fresh plugs and check them at the next oil change or after a few thousand miles, just to get a sort of "base line" read on your new set-up. They should look right to just slightly lean.
Went out and put just over 70 miles on my V-Star 650. I just replaced the stock seat and Protac backrest with an Ultimate Seat and backrest. My friend who so highly recommended the Ultimate said to give it a while for my butt to adapt. I will but it's mixed so far.
It's comfy at first but after about 1:20 my hips and back were hurting and really hurting by 1:40 where I can go 2:30 or so on the stock seat and Protac. We'll see. It sits 1" lower and 1" forward compared to the stock seat. The lower CG makes a noticeable and beneficial difference in handling, especially at slow speeds, and being 1" closer to the bars with my "short for my height" arms is also an improvement, a bit more relaxed flex in the elbows, but being an inch closer and farther forward with respect to the footboards and foot controls takes some getting used to. I feel my legs a bit scrunched up. Though I do seem to be adapting to that, the seat has a 14 day "try it, ride it, return it if you don't like it" guarantee.
I also had just put the highway pegs on and, though I'd ridden since, not really out on the road where I could try 'em out. They're nice for extended open country cruising, especially now that my legs are otherwise feeling scrunched up! I've moved them up a couple of inches on the engine guard since this photo I took last weekend.
Looks great!
Make sure you take the correct size 'Allen' wrench or whatever it takes to tighten those highway pegs because they will always loosen up after a while.
On mine. once I settled on the correct position for the pegs, I drilled and tapped through the peg and the highway bar/ engine guard and installed a small high quality stainless steel bolt in the assembly to keep it in place--forever.
Sam:grin:
