1 - 13 of 13 Posts
That's a fairly heavily customized Honda Nighthawk 750.
Interesting. You call it customized and I call it stripped. :coffeescreen:
It's beenFU%$#@#ED
Reactions: deckerhand
Veteran Member
The CB750 nighthawk was chain driven. That's definitely the Honda 750 DOHC engine. Maybe not a Nighthawk, but definitely a 750 Honda. Perhaps the CB750F? Regardless, it's a personalized bike, beyond whatever it used to be. It's not a bike the OP can go buy from a dealership.
MODERATOR
The 700 Nighthawk had shaft drive.
The 750 Nighthawk had chain drive:
Nighthawk 750[edit]
1992 Honda Nighthawk 750
From 1982 through 2003, with the exception of several years, Honda produced a CB750 known as the Nighthawk 750. Early models were designated the CB750SC Nighthawk while later models were simply known as the Nighthawk 750.[37][38] The Nighthawk 750SC had a 4-stroke engine with a 5-speed manual transmission, chain drive and has front disc and rear drum brakes." Wikipedia
Sam
Honda Gold Wing Service Specialist
Gas tank looks more like a CB750K standard model to me (not an F-model or C-model tank).
But, that's assuming the stock tank is still on it! Probably a big assumption!
Most of the bikes I see used to achieve that style of café burner are mid 1970 - 80's CB 750's.
Easier frame to hack up than the nighthawk if you want a similar (or better IMO) build on the cheap.
Hacking off those big ugly nighthawk tails might make a few bikes look a little nicer though too.
1 - 13 of 13 Posts
