W
wawadave
·Guest
Was looking in google for a norton picture i could scale down for an avatar and found out they are now making new Nortons again i kid you not!!!
http://www.nortonmotorcycles.com/default.asp
FRAME
* Frame material: 4130 chromoly steel
* Swing arm: Formed Aluminium
* Oil capacity: oil-in-frame backbone tank holds 3.5 qts of oil
* Wheelbase: 56.5"
* Rake: 24.5 degrees
* Trail: 4 "
* Front suspension: 43mm Ohlins RSU - Adjustable preload, compression, and rebound damping.
* Rear suspension: Ohlins reservoir-style twin shocks - Adjstable ride height, preload, compression, and rebound damping.
* Front wheel: 3.50 X 17" BST Carbon Fiber
* Rear wheel: 5.50 X 17" BST Carbon Fiber
* Front tyre: 120/70 X 17" Michelin Pilot Power
* Rear tyre: 180/55 X 17" Michelin Pilot Power
* Front wheel travel: 5.5"
* Rear wheel travel: 4.0"
BRAKES & HYDRAULICS
* Front rotors: Brembo 320mm semi-floating hi carbon stainless steel
* Rear rotors: Brembo 220mm rear rotor
* Front calipers: Brembo 4 piston "Gold Line"
* Rear calipers: Brembo 2 piston "Gold Line"
POWER ASSEMBLY
* Engine type: Parallel twin with push-rod valve actuation, dry sump
* Displacement: 961 cc
* Cooling system: Air
* Valve Actuation: Push rod, hydraulic lifter, two valves per cylinder
* Bore x stroke: 88 mm X 79 mm
* Compression ratio: 10.1:1
* Horsepower: 80 rear wheel @ 6500RPM
* Torque: 65 foot pounds @ 5200RPM
* Exhaust:1 3/4" header system with merged collector and twin silencers with catalytic converters.
* Ignition: Crank fired electronic
* Carburetors: Twin 39mm Keihin FCR
TRANSMISSION
* Gearbox: 5 speed
* Final drive: 520 "O" ring chain
* Clutch: Cush drive clutch
* Primary drive: Direct gear drive
ELECTRONICS & CONTROLS
* Charging system: 300 watt hi-output charging system
* Instrumentation: Norton electronic analogue speedo and tachometer w/dual trip meters
MISCELLANEOUS
* Fuel tank capacity: 17l (4.5 US gallons)
* Dry weight: 188kg (415lbs)
* Seat height: 813mm (32")
* Oil capacity in frame: 3.3l (3.5 US quarts)
* Gear case oil: 1.4l (1.5 US quarts)
* Available colors: Black
Specifications are subject to change without notice.
now lord please very very spacial please let me win the lotto i have a reason now!!!
FRAME
* Wheelbase: 56.5"
* Trail: 4 "
BRAKES & HYDRAULICS
POWER ASSEMBLY
TRANSMISSION
* Gearbox: 5 speed
MISCELLANEOUS
