1 - 10 of 10 Posts
I have a cold blooded 2002 Honda CB 250 Nighthawk.
It will start every time with the choke on. I usually turn the choke off after 3 minutes and let it idle for another 7 minutes. It will do fine one flat roads, I can stop and go fine. When I stop on a hill though the revs will slow down and stall.
I have my foot on the back break, clutch in the friction zone, reving up to start to get a pull going, revs start to die down I apply more throttle, clutch is fully engaged the revs keep going down, i have the throttle pulled back pretty far still it will stall if I don't pull the clutch back in.
I come back from a ride and re-test on the same hill the engine doesn't even flinch and keeps going. I don't know what the problem is. I'm not very mechanically knowledgeable, I was hoping to get your guy's input.
If I don't let it warm up for 10-15 min it will stall or the beginning gives me a throttle delay and jerks the bike.
Would love to know what you guys think.
10 minutes should be plenty of time to warm up the engine. My best guess would be either a fouled plug or fuel mixture problem.
I'd try pulling the spark plugs right when this happens and see if they are fouled up.
Sounds like a potential vacuum leak to me. Metal expanding with heat and problem goes away.
I've checked both of the spark plugs they look normal. How would I know of it's a vacume problem? Would I just have to take it to a mechanic?
I personally think it's dangerous but spraying carburetor cleaner around the carb and intake. If it revs up you have a vacuum leak. Be sure to stay away from the hot exhaust though. There has got to be a better way but this does work but be careful where you spray that stuff. It's flammable.
You were spot on, I sprayed some throttle body cleaner around the hosing connection of the carburetor and revs did go up. I think the seals need to be replaced, I'll go in and get the carburetor cleaned while i'm at it. Thanks for all your help, and quick reply. Really appreciate it.
Great. We like hearing that. It still may not be 100% solution but you have to clear one item at a time for complete success. Let's just hope it is just one item.
Pale Rider
I've been told to use WD-40 for the same purpose. Don't know if it is flammable (I believe it is), but it won't damage rubber parts. Cheers!
One somewhat safer way to test for vacuum leaks is if you have an oxy/acetylene torch, turn just the oxygen on very low (no flame) and use your torch tip to look for leaks. Same outcome, if there is a leak the revs will go up. Still have to be cautious as oxygen is as we all know very flammable, but it doesn't get all over the place and make a mess, and is a bit easier to pin point the leak. Just my 2 cents...
1 - 10 of 10 Posts
