No, it won't affect the choke, because it isn't really a choke. It is an 'enrichment' valve, which draws fuel/air mix from the pilot (idle) circuit, and bypasses the throttle. If it happened that abruptly, clearly something got sucked in. Check the air cleaner first, to see if it is coming apart. If it is failing, use a bright light and look into the small holes around the intake throat of the carb. If you spot something, you may be able to clear it with a vacuum source through a small tube.
If the filter is OK, you may have to drop the float bowl, and look for something stuck in the main jet. You may need to find a service manual to see how to take it apart enough to clear it. I don't have a manual for that model, and the carb is different from the ones on the VS800 and VS 1400. If you find black grit in the bottom of the bowl, it is probably the fuel line breaking up in the inside.
