Since voltage drop testing is probably the single most important electrical diagnostic skill you can have... I think about it a lot.
Including different ways of explaining it for those who haven't "got" it yet.
So here's another.
Wires, contacts (in switches and relays) and connectors all have resistance.
All new and shiny, it's a very LOW resistance.
(As a reference point, 1000 feet of 14AWG stranded automotive wire has approximately 2.5 ohms)
Once contacts get worn or burned, connectors get corroded, and half the strands in a wire broken from flexing back and forth..... that resistance can increase considerably.
But it's STILL too low to measure effectively with an ohmmeter. Realistically, an ohmmeter can't measure anything ACCURATELY below, say, 10 ohms.
How hard you press the test leads to whatever you're measuring can cause your reading to vary by several ohms.
A corroded connector, or a ground connection to an auto or motorcycle frame might only add 1/10 of an ohm, .1 ohms, to a circuit.
That doesn't seem like much, but it can be enough to dim a headlight, cause a starter to click instead of spin, or cause all sorts of problems with ECM's and sensors.
So the way you FIND those corroded connectors, burned contacts, bad grounds, loose connections, etc is not by using an ohmmeter.
It's by using Ohms LAW.
Volts = Amps * Resistance.
If you have a 10 amp headlight, and a corroded headlight switch that adds .1 ohms of resistance...
I * R = the amount of voltage LOST passing through that switch, so
10 amps * .1 ohm = 1 volt.
So instead of the headlight getting a full 13.8V while the engine is running, it's only getting 12.8 volts. And as a result it's only about half as bright!
The key thing here is that a voltmeter CAN very accurately measure voltages, even down to millivolts (thousandths of a volt).
A one volt "drop" is easy to measure, unlike a .1ohm resistance.
So you turn the headlight on, and compare the voltage at the battery (alternator) with the voltage actually reaching the light.
Current HAS TO BE FLOWING! V=IR only works when I is non-zero! In other words you have to have the headlight ON, and illuminated.
You can't measure a voltage drop to a non-energized circuit!
Let's say you find the headlight is only getting 11.8 volts with the engine off, but the battery measures 12.6 volts.
You've got a voltage drop of .8 volts.
So you stick the black lead on the battery (-) terminal, and "walk" the red lead of your meter along the outputs of the (in this order)
battery + post
main fuse
ignition switch
dimmer switch
headlight connector
headlight socket
Say your readings at these points are
12.61 volts
12.60 volts
12.55 volts some drop is expected, acceptable...
12.49 volts
11.9 volts ***
11.87 volts
*** THERE IT IS! Between the dimmer switch and the headlight connector you've lost .6 volts. That's a lot!
You probably need to pull the headlight connector apart, clean/wire brush the contacts, and put it back together.
Your headlight will be noticeably brighter!
So what is a "bad ground." If you've got a wire bolted or screwed to the frame of your bike, whether to provide a taillight ground or whatever, and that is all rusty, corroded, loose, or even...bolted on top of fresh paint instead of bare, bright metal....chances are yo'uve got a "bad ground" with anywhere from .01 to .2 ohms of unwanted resistance.
A voltage drop occurs when current flows through an unwanted, un-planned for, or unexpected resistance in a circuit.
Now get that meter out and go find 'em!
So here's another.
battery + post
main fuse
ignition switch
dimmer switch
headlight connector
headlight socket
12.61 volts
12.60 volts
12.49 volts
11.9 volts ***
11.87 volts
