Virago 535 tapping
2065 Views 1 Reply 2 Participants Last post by  cmonSTART
https://www.youtube.com/watch?v=atmC99pWH7A&feature=share
I have a problem, there’s a tapping noise on the virago 535 1996 the back cylinder runs better than the front and I took spark plugs out the back was black but dry and the front was black but wet, I can adjust the richness but there’s defiantly something wrong here also if I take the spark plug Cap off the front cylinder when it’s ticking over it’ll stay ticking over but off the back cylinder but if I do it the other way round the bike would turn off
1 - 2 of 2 Posts
Sounds valve related.
I can't remember - have you tested the compression up front? Also, can you put a spark tester or timing light on it to check for a spark signal?
1 - 2 of 2 Posts
