Speedo/tacho/voltmeter bracket made up today. I'll be adding a few LEDs later on for oil, indicators and so on.
Is that buffed stainless steel? Looks good whatever it is.Speedo/tacho/voltmeter bracket made up today. I'll be adding a few LEDs later on for oil, indicators and so on.
What about Mikuni flat slides? Might be a bit tricky to set up - but they certainly do improve performance.Some progress shots. Looks much better with spoked wheels. I've taken the carbs off as one diaphragm has been holed, so, I'm tossing up between VM round slides or fixing the BS38 carbs. Not real keen on vacuum carbs, so leaning toward the VM round slides. Damned expensive though at $600. It's come a long way from such a humble beginning.
I'm actually running Chinese Mikuni knock-offs on my two 250 singles. They work well and only cost around $30+ AU...and if you are never going to ride it then they might be a good option.Oh no, have you seen the price of flat slides? Round slides are expensive enough. I've got to draw a line somewhere. Performance doesn't interest me anyway as I'll never be able to ride it, so no point.
But do you think you could get two that are identical? It would be a real pain if somebody had to do totally different tuning for each cylinder.I'm actually running Chinese Mikuni knock-offs on my two 250 singles. They work well and only cost around $30+ AU...and if you are never going to ride it then they might be a good option.
Sorry - I meant Keihin PWK carbs. The two that I bought were branded 'Maikuni' - so that stuck in my mind. They came wrapped in foam in a nice little metal box, with two spare main/pilot jets, needle and some fuel line.What has been you're experience??
I've also heard about knock off PWKs not being up to scratch either.
If bought from the same seller it could be assumed that the carbs might be identical - from the same factory. Although, even if they aren't, two cylinders isn't a major tune anyway.But do you think you could get two that are identical? It would be a real pain if somebody had to do totally different tuning for each cylinder.
Wrong. Everyone is just watching. They jump in if or when they think you are going wrong. But we can't change your mind if it's set.End of posts here, no interest on classic bikes.
