Vendor
Checking the tire pressure regularly is crucial to your riding safety. Underinflated tires run hot resulting in the reduced lifespan of your rubber. Besides, in this case, it may be harder to handle your bike. Fuel mileage is also reduced. In extreme cases, you may end up with a blown tire, damaged rim and other problems. In other words, low tire pressure is an accident waiting to happen.
If the pressure is higher than normal, your tires become too stiff reducing the contact patch on the road. It reduces traction and makes your motorcycle unstable on gravel or bumpy road. And there is the probability of a puncture. You would want to have a monitor that can show you the accelerated tire pressure drop so that you could stop safely and fix the problem. In this case, the TPMS Kit by Torxe, which can be mounted on your handlebar, would come in handy.
TORXE™ TPMS-02 - 2-Tire TPMS Kit – MOTORCYCLEiD.com
Specifications:
Frequency: 433.92MHz
Monitor display output voltage: DC5V
Monitor working temperature: -4ºF - 176ºF (-20ºC - 80ºC)
Monitor storage temperature: -22ºF - 185ºF (-30ºC - -85ºC)
Monitor dimensions: 2.28”L x 1.89”W x 0.90”H (58mmL x 48mmW x 23mmH)
Monitor weight: 1.83 oz. (52g)
Sensor transmission power: <10dBm
Sensor working temperature: -40ºF - 176ºF (-40ºC - 80ºC)
Sensor storage temperature: -40ºF - 185ºF (-40ºC - 85ºC)
Sensor pressure range: 0-87 psi (0-6 bar)
Sensor pressure accuracy: ± 1.5 psi (± 0.1 bar)
Sensor temperature accuracy: ± 6.3ºF (± 3ºC)
Sensor battery life: more than 2 years
Sensor dimensions: 0.82”D x 0.688”H (21mmD x 17.5mmH)
Sensor weight: 0.31 oz. (9g)
Features:
Monitor displays pressure or temperature for both tires simultaneously
Easily toggles between pressure and temperature displays
Pressure unit selectable (psi or bar)
Temperature unit selectable (Fahrenheit or Celsius)
Warnings for high pressure, low pressure, high temperature, fast leakage, and sensor low battery
Alerts warning with flashing display and audible alarm
Programmable with selectable parameters
The monitor contains a rechargeable battery
Monitor battery recharges via included USB charging cable
Monitor backlight illuminates automatically when ambient light is insufficient
Monitor battery saving mode – shuts down after 15 minutes when the bike is not in motion
2 valve stem mount sensors
Sensors contain CR1632 replaceable lithium batteries
Includes tool to disassemble sensors for battery replacement
Warranty: 1 year
To browse all available tire pressure monitoring systems, click on the button below:
If you have any questions, feel free to ask them here or call our tech experts at 888.903.4344
Do they make a 3 tire version for trikes? Been looking for something for my wife’s Spyder. I don’t like the idea of getting a car version then not use one of the senders. So a good triple version would be great.
Very Famous Person
I have a setup like that. I'm not sure if it's the same brand, but it looks identical. Works well. The audible alarm is no good, although not that important probably, as you can't hear anything with a helmet on and you're moving. Mine cost closer to $200. though.
Vendor
Discussion Starter · #4 ·
Not that I know of. They usually come in pairs or in 4-piece kits.
Alternatively, you can buy 3 single-piece Bluetooth sensors with an app. ($95.97 each)
Thank you for the feedback!
