I have a 1981 Honda cb650. I have cleaned the carbs, checked float heights, and installed new needles. I can't get the bike to idle. If I choke it, it will stay around 3000rpm then shoot up to 5500 rpm. And when I push the choke in, it dies. I checked the temp of the pipes and the two on the left are around 130 degrees and the right two are around 240 degrees. I checked the spark and had good spark on all 4. Compression is good and equal on all 4. I also dont have any vacuum leaks.
I returned the fuel mixture screws to factory settings, and bench sync the carbs.
I guess I'm just not sure how to adjust the fuel mixture screws if I cant get it to idle and hear the difference. If the left two are set too lean, could that be why its running cold?
Any help would be appreciated. Thanks.
They are on the bike now, I don't believe there was. All the butterflys were flush along the bottom. I don't know if there are other ways of bench syncing them, but I used two drill bits on the same size and made them all equal to the main carb.
