Hello! :grin:
I've got this '96 Bandit 600, andI've got some problems.
The issue in itself is that when I idle it, it won't really run without stalling. So I turn up the idle screw under the carbs, which results in the bike idling at 3,5k rpm when riding (so when I pull the clutch it goes up to 3,5k ish, which isn't ideal). Then I turn it back down when I come home from the ride, so it idles at about 1200-1500rpm, but when I start the bike again it won't idle at all unless I use the choke until it's at riding temperature (could start the bike without choke at a warm summer day last season). And on and on.
So the reason why this happened;
I went over the carbs, due to bad idle, swapped out the pilot screw o-ring and the float chamber gasket and took a general check and cleaning of all the bits of the carb (using a Haynes manual since it was my first time, and I have a good mechanical insight). I also drained the tank and checked the fuel tap, because it's f*cked and will only work at "reserve", while it's in the "ON" position it drops vacuum-level unless I go hard on the throttle.
lain:
Things I have checked;
Pilot screws and positioning + spark plugs, looking good.
Vacuum leak around the carb, nothing at all.
Idle channels that goes from the induction side of the carb to the exhaust side, carb cleaner and carefully with compressed air, nothing in there at all.
Vacuum in the carbs, looking good.
Things I want to check, but cost money;
Coils and spark plug wires, just a thought, but have no idea.
Fuel tap, since it is working badly at ON, it might have gotten worse vacuum at "reserve" after I split it open and tried to clean it (expensive as hell appearently).
Choke wire, it seems to be a little short and is always in a bit of tension (no slack at all). Doubt it, but I can try this without getting a new one.
Now then, please if anyone could give me any tips I would be SO happy.
Best Regards,
A tired Bandit owner :crying:
Best Regards,
