Hi everyone,
Background:
I have a 2007 honda cbr 125.
It was stolen a few weeks ago, driven pretty wrecklessly, and now i got it back.
Problem 1:
Driving up hill, i get sort of hiccups on the motorcycle.
Like it slips out of gear for a second then reconnects.
When it slips, i lose thrus for a second, then like the gear reconnects and regains the thrust. It can happen every few seconds going up hill, and seems to get worse.
This can happen in first, second, third gear... probably even higher gears..
When i go on a flat road, not up hill, i dont get this issue.
If im driving someone, so the bike is heavier, this issue is more noticeable.
Problem 2:
Driving down hill, allowing the motorcycle to be slowed down by the current gear, i hear a grinding clunking sound. It sounds as if some clutch plate and the gears can't connect so they are just clunking at each other, if this makes sense?
I drive down hill, no need to use gas since im going fast enough, i let go and i hear these very scary metal clunking noises, even if i slow down with my brakes they are still hapening.
If i hold down my clutch the noises stop.
So now when i go down hill, i either accelerate with gas, or i have to slow down by holding the clutch and the break.
I can't let the motorcycle ride the gear down hill because of the metal hitting noises im hearing.
Both of these problems can happen on a straight road as well, if the forces are strong enough. Like if i drive fast and then switch the gears down i will get the clunking noises.
If im driving another person in the back i might have gear hiccups on almost straight roads, etc..
Any ideas? These problems seem to be getting worse.
Is it something i can fix by myself?
Background:
Problem 1:
Problem 2:
