1 - 2 of 2 Posts
Just pulled the cover of the right side of my transmission. Got a lot of water and rotten oil from it. Would like to flush the trans but I dont see a drain plug for it. Is the primary oil and trans fluid the same?:frown:
94 evo
Nope, you have separate oils. I think you had a Softail? The transmission drain plug should be underneath on the bottom of the transmission, right up between the shock bodies.
1 - 2 of 2 Posts
