1 - 11 of 11 Posts
Hi
I have looked through my owner's manual to try and find torque settings for the two bolts on the brake caliper, but couldn't find it.
If anyone has got a larger manual or knows the common torque settings for the CB series, then it would be much appreciated.
Being a Honda rider, checking brakes is operator maintenance, changing brakes is not
My Suzuki owners manual says 28ft-lb or 39 N-m
Us Suzuki riders are more mechanically inclined
I'm talking about these two bolts that hold the caliper in place:
Would it be dangerous to tighten these bolts without giving them a specific amount of torque?
It would be dangerous not having them tight enough, and too tight would twist the head off
As mentioned use some blue loctite, other brands thread locker might be a different color
The bolt will twist down to where it is hitting solid metal
Use your ratchet holding it up next to the socket and turn until it hits solid, slide hand out to end and give it a bit of a twist........nothing shakes rattles or rolls the loctite will hold it good
If you need a number use the 28ft-lb, that's certainly NOT enough to twist the head off, but enough to have the head snug
There are standard universal torque specs for every bolt depending on size and thread pitch.
Google can probably help with that.
Other that that... Tight enough so that it does not come lose but not so tight that it strips anything.
(FYI) Most calipers use strong, high grade mounting bolts.
I used to do things right or left handed or thumb and pinky finger or as tight as three fingers would allow. That was before I got a good inch pound and a good foot pound torque wrenches. I was amazed at how close I was getting. But then after stripping so many threads I was getting tried of that. But red(271), blue(242) and yellow(577) Loctite can go a long way in keeping things together.
Reactions: FlipFlop
2016 Honda Rebel 250
Beware! and be aware that Loctite Red is intended to be permanent and requires 550 degrees F to remove:
Loctite Blue removes without heat.
1 - 11 of 11 Posts
