Yes, but I bet you'd break a lot less drills using one that big. :smile:The 1/8 hole for the lock wyre is too big.
UK
The lack of bolt left after drilling is the issue.Yes, but I bet you'd break a lot less drills using one that big. :smile:
You'd also have a lot less bolt after drilling... :surprise:
We drilled the pointy edge area, not thru the middle. And smaller than 1/16. Lock wyre is 1/32 or less from memory. Jim Dunn from WA had a cool tool that twisted the wyre. Common now but rare then. He taped 6 inch pieces of wool to the fairing. Took photos of it at speed. Old style wind tunnel.Yeah, a brake caliper bolt with a 1/8" hole all the way through. Hmmmm
What could go wrong .... :surprise:
Pointy edge: YepWe drilled the pointy edge area, not thru the middle. And smaller than 1/16. Lock wyre is 1/32 or less from memory. Jim Dunn from WA had a cool tool that twisted the wyre. Common now but rare then. He taped 6 inch pieces of wool to the fairing. Took photos of it at speed. Old style wind tunnel.
UK
Smaller that 1/16" ? :surprise:We drilled the pointy edge area, not thru the middle. And smaller than 1/16. Lock wyre is 1/32 or less from memory. Jim Dunn from WA had a cool tool that twisted the wyre. Common now but rare then. He taped 6 inch pieces of wool to the fairing. Took photos of it at speed. Old style wind tunnel.
UK
