Hi all. ******* here. I just recently replaced the carb on my 78 twinstar CM185 with an ever so slightly different one. Since then, the throttle has had so much slack in the cable that if I were to twist it all the way out, I can twist it back about a quarter turn before theres even any tension.
Also, when the throttle is all the way open it doesn't spring back quite the way I think it should. I've already moved the adjustment nut/screw thing as far down as it can go and theres still so much slack. Is there some other adjustment I missed or did I do something wrong with the carb? Please tell me how to fix this cause I can hardly get any acceleration with so little throttle to work with!
