I was looking at my 1975 Suzuki TS185 and noticed something odd. on the bottom underside of the Exhaust there is a Large threading. nothing is threaded into it and after i had the engine running awhile a black liquid was dripping from the threaded hole. so i found a bolt that fit and i wrapped it in some plumbers tape and the leaking stopped. the hole is about 2/3 down the length of the exhaust and my dad thought it might have been for a vaccuum tube or something but i dont know. id guesstimate the diameter to be about 10mm being familiar with bullets and bolts. if you look closely i have circled the bolt sticking out of the exhaust in yellow.
My guess is that it would be there on purpose to allow the system to be drained every once in a while to prevent the exhaust from rotting out. The black fluid is probably a mix of water, fuel, oil and carbon. Most two stroke (and four stoke) motors that have an up swept exhaust system will have that feature, as the moisture/fuel would just sit there otherwise. I hope you understand what I am saying, and nice bike by the way. the reason there would be a bolt there in the first place would be for engine performance purposes, as the expansion chamber needs to be sealed for scavenging, back pressure etc.
So do you think i should leave my ghetto bolt in or take it out? and thanks. Man i love that bike (your avatar) id love to own one. what is it a GS550?
