1 - 12 of 12 Posts
Hello All,
New to the forum. Got a small problem with my bike and you all seem like a smart bunch.
While idling, I occasionally here a tapping some like a rock or something has bumped against the inside of the motor, and when this happens, the motor seems to struggle for a fraction of a second.
Does anyone know what this could be?
The bike is a 2009 Suzuki GS500f.
Thanks in advance,
Andrew
Noises are tough via the internet. You can try uploading a video to Youtube and posting the link here - that sometimes helps.
Where does the tapping seem to come from? Top, bottom, left right?
In that case, hold your hand against the spark plug boots while it is running; if the spark is jumping around the plugs, you'll know.
And learn new cuss words.
And crash if it happened to me. I hate getting shocked and jump right out of my skin, practically. Better to use a voltmeter and just run one probe around watching for any sudden reading. If sparks are jumping you'll get a reading at some point. May take awhile but it will happen. Or just change plug wires so you eliminate that possible problem. 2009, yep, they need changed anyway if still the OEM's.
Perhaps a safer way is to start it in a dark place, maybe cover the headlamp, and look for little blue flashes near the coils or plugs. Then use a spray bottle around the plugs and coils. Spark leaks will usually show up right away.
You might also put a wrench on the plugs, to make sure they are plenty tight.
1 - 12 of 12 Posts
