⬇⬇⬇ Very comprehensive reply.
I hear the sound in my Pulsar's swing arm bush as I press the back suspension area again & again. I know it will be solved by greasing the bushes but my question here is, What if I don't? Or how does it affect my bike's performance? What benefits I get after greasing?
You nailed the answer that I wanted.. thank you so much bro
- Materials cost: Grease is cheaper than new bushings.
- Time: Maintaining the bushings with periodic lubrication will take less time than installing new bushings.
- Safety: Unnecessary friction eventually leads to failure. Sloppy worn bushings can cause side to side wobbling especially at higher speeds or while cornering. This makes you a danger to yourself and others.
- Reliability: A well maintained bike is more reliable. Breakdowns and roadside repairs seldom happen at a good time.
- Resale value: Squeaking, wobbling, poorly maintained bikes are worth less than properly maintained bikes.
Today I have prepared them for greasing but, what I found out was shocking.. I noticed a little slack/play between the bushes & thought it needs to be replaced with new bushes. You can see the difference of the chrome coating as I posted a pic below. It is worn out, no?
leads to failure. Sloppy worn bushings can cause side to side wobbling especially at higher speeds or while cornering. This makes you a danger to yourself and others.- Reliability: A well maintained bike is more reliable. Breakdowns and roadside repairs seldom happen at a good time.
Search Community⬇⬇⬇ Very comprehensive reply.
Today I have prepared them for greasing but, what I found out was shocking.. I noticed a little slack/play between the bushes & thought it needs to be replaced with new bushes. You can see the difference of the chrome coating as I posted a pic below. It is worn out, no?Oz said:
Yes.. exactly you're right. That's just what happened with my bushes. So, I must replace themIt is possible that the bearings did not have any grease when assembled. And it is possible that there is no grease nipple.
That type of bushing is often bronze. What looks like a chrome coating / colour, could be colouring from another source.
TQ so much bro for your time..Not sure how Pulsar's swingarm pivot is configured. There's usually roller-bearings on outside of those collars. Or bushings on outside, which most likely need to be replaced as well. Along with seals on ends. They usually come as kit like this:
EDIT: Found parts for Pulsar. 4 bushings over 2 collars:
Bajaj Pulsar 150 UG4 DTS-i: Swing Arm
Bajaj Genuine Swing Arm for Bajaj Pulsar 150 UG4 with 150cc DTSi Engine in authentic quality and price. Express delivery across Indiawww.99rpm.com
You're most welcome!TQ so much bro for your time..
