1 - 13 of 13 Posts
Hello all....Riding home from work yesterday, I noticed that when I moved out in first gear I was hearing a strange clicking sound. It seemed to me like the sound when switching gears. The bike made little herky jerky moves as this was happening. Same thing when I was slowing down. The sound was definately coming from the back of the bike. I got a little worried and pulled into a gas station. I checked all the wires and chain, not knowing exactly what I was looking for. Just wanted to see if anything looked out of the ordinary. I figetted with the wires. Lo and behold, when I left the gas station(about 2 miles from home) I didn't have the problem....Any ideas of what this could be?
Well, it could be a lot of things. What kind of bike is this?
Not a bad idea to give the bike a good look-over when you have a chance. How is the clutch cable?
Wheel bearing? All your oil levels where they should be? That's chain and not drive-shaft correct?
a rock in the tire?
Discussion Starter · #5 ·
It's a 2010 g650gs cmonstart. It's about time to have it serviced anyway before the weather breaks for us riders. Thanks to you all for your responses.
Discussion Starter · #6 ·
I looked over the bike this morning and didn't see anything out of the ordinary. I rode around the block and something is not right. It's definitely coming from the back of the bike. Does motorcycles make any noise if the chain needs adjusting?
If the teeth on the sprocket are worn away to nothing, it can start slipping - have you changed chain and sprockets?
*edit - no offence intended, this is something I learned from experience in the early days
Something rubbing in the brake rotor?
Discussion Starter · #9 ·
Donny thanks for the knowledge. I brought the bike with 5000k and now have 17000k in two years. I ride year round. Should the chain or sprocket be changed by now? I don't have a clue but I can check the sprocket. I cleaned and lubed the chain a couple of weeks ago and didn't notice anything. That was before the trouble started.
Hi Critter. I do believe it's that's a good possibility. It's definately something back near the wheel or brake. Thanks.
Discussion Starter · #11 ·
My new bike mechanic checked the chain and sprocket for me couple of days ago. Had a service done. He said that I'll need new tires at about 2-3k, so get everything done at once. This guy has an excellent shop and seems very skilled. He test rode the bike to listen and feel it out before he did anything. I think that was really cool. He had at least 20 Beemers in his shop, and BMW's are what he specializes in. I had a 12k service done (without valve checks) for a whopping $130 bucks. The dealers price for the same thing was quoted at a little over $500. That's one hell-of-a price difference. It was a 50 mile ride to the shop but well worth it. Bikes running great.
I'd still be on my Beemer if I could have found someone like that. But you live in that junk and I live in God's country. I'll take my bumps!:p
1 - 13 of 13 Posts
