Engine cold, turn key, choke it, give it some gas, check kill switch, stands up, gears right, push button....
work it work it.... dedicated work it, sometimes it starts....
like only one or two cylinders then they each fire up as it warms up....
But then there is the syndrome....
Engine cold, turn key, choke it, give it some gas, check kill switch, stands up gears right, push button
grind grind.... spits some gas through the air jet.... grind grind....
refuses to spit gas through air jet. battery fails....
new plugs and wires, coils all check out. This happens mostly when the tank shows nearly empty. I have not cleaned the tank but I did drain it and clean the petcock. fuel pump ok. No errors on dash idiots.
IF it was something bad it wouldn't start at all.... its like its trying to tell me something....
1983 Yamaha Venture Royale XVZ12TDK
