1 - 12 of 12 Posts
ok, how the hell do i get old bearing race off? I did quick search and it looks like i need a tool for like $400 or a welder to heat it up. any other good trick to get it off?
cheers
The right tool for the job. Being down under you probably don't have easy access to a dealer but that is where I would go and just see if you could borrow it. Haul your unit there so you use it with them looking on.
don't think they would be to happy to help me. why would they help me fix my own bike where they could do it for me and make money? but i will try it if i won't find any other way. thanks
I've had to cut them off of stems before - very carefully. You don't want to damage the stem, but if you can cut most of the way through them with a small cutting wheel, usually a good cold chisel will break through the rest of the way.
yeah, true. but i'm hoping to get it done myself. was thinking to try to do that like that guy... just cut it with a grinder.. is it bad idea?
Discussion Starter #10
Gandalf, I've always just used a small hammer and a pin punch to drift them in. Go gently and work your way around the race so it goes in straight, like picpoc said.
Discussion Starter #12
hi, so i got new bearings in. put bike together and it was all fine. But after few days of riding i have noticed that the flat bolt that keeps the stem and bearings in place tighten itself by about half a turn. is it normal? thought that i may missed a washer or something but it looks like everything is there. at the moment i worry that if that keeps tightening it will stuff my bearings again.
1 - 12 of 12 Posts
