1 - 10 of 10 Posts
Do they make a spray on sealer that I can spray on my old carb boots that will seal the cracks thus reducing my repair costs(way over budget on this "venture")
The most common problem with cracked boots is that the material has become brittle with age. There isn't anything that can repair them when they start to crumble as far as I know.
I have "painted" them with black RTV before, and it has worked, but it's a very very very temporary thing. Eventually it will fail - and probably soon. Do it, see IF it helps, but don't plan on it being permanent.
Another cheap band-aid you can do for old carb boots is a wintergreen oil soak. Google it. It also may HELP you eek a bit more life out of them.
As Dods said, once they reach a certain point there's not much you can do. Replacement is best, but I certainly understand having to make budget repairs.
testing testing always testing
how about a dunk in a hydrochloric acid or something?
Muratic acid? what kind of acid do you use on styrene pvc or what ever?
Aging & Worn
What would a new set of boots cost? I had a double boot setup on my 86 Shadow.
I like the idea of putting a coating on them as the folks have suggested so far. I agree it would only be a short-time fix.
Too bad you couldn't heat them in some way, and cause the rubber to mold together again.......
-Soupy
Just FYI, sealants are temporary because the boots are constantly flexing with the throttle changes. This flexing will quickly break up anything used to temporarily seal the cracks.
1 - 10 of 10 Posts
