So I had recently put the front wheel on and I rolled it out of my shed.Then I hear a snap and I look down and the speedometer cable broke. Further investigation, I saw that the whole speedometer assembly that is on the wheel rotates when I spin the front wheel. Im pretty sure that isn't suppose to happen. Looking at the front wheel assembly diagram, all you are supposed to do is put the axle through everything and the speedometer acts as a spacer as well. So Im not sure why the speedometer assembly is rotating about the axle. Did I tighten the wheel axle nut too much?
Also, for the broken speedometer cable, is this something that I can just clean off the dirt and then use some sort of epoxy on it?
