I recently bought a 1981 honda cb650 custom for a few hundred bucks with 6300 miles. After picking up a new battery I managed to get it fired up for a second or two using starting fluid (I know im bad). it will run/rev up then die second or two after spraying. Leads me to assume I have a fuel delivery issue most likely the carbs (previous owner said the carbs need to be cleaned). My main problem is finding info about cleaning the pilot jets which are pressed in not removable ones.
1: Can I use a screw extractor like method to pull them out?
2: Can I/Has anyone ever removed the pressed pilot jets then drilled hole slightly larger to add thread repair inserts so you can simply put in the adjustable pilot jets that were added to the 1982 (year later) model?
Any advice helps and is much appreciated!
