The tires will have a date code on them indicating when they were made. Also check your neck bearings.
Did the road you were on have rain grooves?
The tires will have a date code on them indicating when they were made. Also check your neck bearings.I dont know how old the tires are, they are in good condition. Previous owner may have a log .
At high speeds, it doesn't take much to get a slight wobble. Since you found a problem with the shocks, I would definitely start there.I did not see a date on the tire, maybe cant find it, Did see that the shocks were slightly off. I just let all the air out of them to see if it helps.
There was no rain grooves on the roads I tested . I haven"t check the bearings yet.
There was no rain grooves on the roads I tested . I havent check the bearings yet.
You'll want to put proper amount of air-pressure back in. No pressure would make them soft and more prone to shaking. Make sure both sides are balanced.I checked if there was any give or wiggle in the tire when up in the air. It had no give and was nice and solid.
The only thing I can think of is that the tire sidewall cut is effecting it. I did not take it out at high way speeds since checking the shocks.
The sidewall cut is where the tread part meets the sidewall.
The tires could be mismatched. Also, just because the "problem" is in the front doesn't mean the issue isn't the back tire. What tires are recommended and what do you have on the bike right now? Not just the make but the model.The tires will have a date code on them indicating when they were made. Also check your neck bearings.
That sounds like a tire separation. Those are more common on car and truck tires than motorcycle tires, but they do happen. Had a friend that happened to on a brand-new tire, had to fight with the manufacturer to get it warrantied. This was back in the 80's and the manufacturers didn't have warrantees for motorcycle tires.Tires can look good, but have a problem.
I had a continuous bouncing of my from wheel at about 65. Tried a few different ways of balancing it. Did not work. A new tire fixed the problem. I also had a steering direction problem, mostly on the freeway. New steering head bearings fixed that problem. Best to check everything as suggested in the posts above.
yes! I recently rebuilt entire front-end on my Cbr600rr track bike due to shaking under braking. I suspect there were multiple issues. Fork bushings was definitely one of problems.I would check wear on the front forks.
Thanks, Danno. I should have specifically mentioned bushings. The OP's bike is 15 years old so they deserve a look.yes! I recently rebuilt entire front-end on my Cbr600rr track bike due to shaking under braking. I suspect there were multiple issues. Fork bushings was definitely one of problems.
Couldn't feel any looseness from wiggling on outside. But thats because I couldn't overcome spring pre-load by hand. But when disassembled, bushings had copper showing. Definitely time for replacement.
I did check this and there was no give . Everything seemed solidYou have not said much about the steering head bearings.
It is always a good plan to inspect these parts.
And therein lies the problem in an easy diagnosis. It could be a number of things or even more than one thing. One thing is for sure, wobble is not good.Wobble will happen at: Tire mis-inflation, head bearing wear/torque, wheel bearing wear/torque, wheel alignment, fork alignment , wheel balance, weight balance of bike load, frame flex/bent(this is actually under wheel alignment though).
Each is unique feel and knowing how to do it all is best for you to learn how too so you know it is right and do not pay someone for something that you will end up checking your self usually anyway. Learning how to diagnose each is easy. Fixing is only a level higher than that for each.
It may seem solid. BUT. The front wheel needs to be off the ground, and the check is for a non smooth turning of the steering head. That was the simple explanation.I did check this and there was no give . Everything seemed solid
