How old and how worn are your tires?
I dont know how old the tires are, they are in good condition. Previous owner may have a log .How old and how worn are your tires?
Probably not but, anything is possible.Can different front shock pressure cause it?
That bike has individual schrader valves on each side making each tubes air pressure independent. The recommended range is between 0 and 7 lbs. I would get one of these pumps to control the pressures. Also you have another valve on the back right by the front of the hardbag. That one controls the rear air pressure. Off the top of my head the range is 0 to 45lbs.Can different front shock pressure cause it?
It could, depending... A cut in the sidewall might be a clue that there is more damage you can not see from the outside.I inspected the front tire, and noticed a small cut on the side wall. Where the tread meets the sidewall. The tread is good. But could this be the issue?
