I could use some advice fine tuning my bike. She starts and idles fine. After she warms up for a minute and I drop her into first gear I get some hesitation and sputtering at lower RPM ranges from 2 to 3 rpm. This is consistant in every gear I am in. Runs good around 4 rpms.
After a 10 mile ride I pulled the plugs to get a reading. Attached are some shots of the front and rear plugs. I suspect the front cylinder looks a bit rich. But I could be completely wrong.
Anyone else have some thoughts. The coils have been tested and they are all good. Also compression on both cylinders is 120 psi.
As you can see the reading are not consistant. The front spark plug seemed much darker, almost wet looking.
The rear one was browner and seemed hotter to the touch.
Any thoughts would be helpful.
