Does the helmet have a clear visor that can be flipped up, as well as a sun shade inner visor that can flick down? Usually this would be a full face helmet.I have a helmet with a dark visor. I was just testing it out at home and I noticed that in some lighting conditions, I can see my reflection in the visor. I don’t want to have to wear sunglasses inside the helmet. Is this normal?
You got me totally confused now. Are you saying the clear visor fits differently than the dark visor? I've never seen a dark visor that replaces a clear one, that came with the helmet, fit differently. So I don't understand why your sunglasses would fit different under each. Or are you saying you put a "universal fit" dark visor on replacing the factory clear visor. If that's true, then I'm not surprised. Manufactures go to great pains to make helmets and the visors work as intended. So unless you use their visor, I don't think they can help and we certainly can't. But maybe that isn't what you are saying, hence my confusion. So could you clarify?It’s a full face. It came with a clear visor that I replaced with a dark gray because I don’t think I could fit sunglasses under there, anyway. This particular model does not have the flip down sun shade.
Unless the maker states that they have anti-glare coatings (haven't seen one, yet), all face shields will reflect the light that hits your face. A dark shield just works like a 'one-way' mirror, because the scene in front of you is darkened, and you may see the reflection better. If it bothers you, just turn your head enough to change the angle of the light bouncing off your face; that's what I do.My experience with a dark shield is the same as yours -- I get an irritating interior reflection. Fortunately with my HJC CL-17 helmets there is room underneath for glasses -- fortunate, since I wear glasses to see! In fact, even the rather goggle-like sunglasses-over-glasses type eyewear will fit under the clear face shield.
Are you just assuming or do you know for sure sunglasses will not fit under your face shield? If the former, then try it out first; if the latter, you're either stuck with the dark face shield and it's reflections, doomed to ride with no sunshade, or you'll need to find a new helmet.
