Hello everyone,
I’m having a strange issue with my bike and wanted to see if anyone has experienced something similar.
The bike:
Sym NHT 200cc (EFI single, stock) 2023
Fuel pump: new (3 months old)
CKP sensor: replaced recently (1week ago)
Stator: replaced recently( with ckp)
Battery/charging: 14.1V when running, 12.5V engine off.
- Whole Clutch replaced recently as well.
The problem:
The rev limiter behavior has changed: it used to sound like the typical “bwaaah bwaaah” fuel cut, but now it’s a rapid bursts of “atatatatata” ignition cut style similar to a machine gun.
Top speed in all gears is reduced compared to before.
Example: in 3rd gear I used to reach ~94 km/h at redline, now only ~75 km/h before limiter.
In 6th gear, however, the bike still reaches its normal top speedeasily but get limited in rpm
When i hit 75kmh in third gear i can hear the engine screaming and if i continue holding WOT the bike kind of still accelerate a bit while rev limiter is engaging. And this happens in all gears
The rpm doesn't show in dash because of a burnt diode( it's an unrelated issue with the instrument panel)
Other notes:
-Bike runs normally at low and mid RPM.
-No issues during regular commuting—only near redline.
Sometimes when bike is cold i can get the top speed in each gear to rise a bit
-Changed clutch kit, with an OEM.
Has anyone come across this kind of behavior?
Thanks.
The bike:
The problem:
Other notes:
Thanks.
