1 - 8 of 8 Posts
Hello I am not new to riding motorcycles but have never experienced something like this in first gear when I am letting the clutch out to take off my motorcycle jumps and grinds but if I am just riding in second and go to first it runs just fine in first until I get the clutch involved what could this be any help would be appreciated by the way I have a 1997 suzuki gsxr750 and I thank it is the clutch but like what parts inside would I be looking to buy
Aging & Worn
Not all that long ago, I was messing with my clutch cable, where it is attached to my handlebars. I found that if I had it adjusted too far one way, I had no clutch response; too far the other way and well.........you get the idea.
Let's start with that.......is your cable set correctly?
-Soupy
Well I thank so it seems to do fine in the other gears because I take off in second witch does make a little sound some times like a little click noise very quit
Discussion Starter · #4 ·
I did have to put a new one on when I first got it because the guy before me had almost snapped the last one from having it so tight
I'm not sure what is meant by "jump and grind". Grinding noise is a sign that something is seriously failing in the drive train.
Discussion Starter · #6 ·
jerk felling and a noisy gear grinding sound like you will die 90 percent of the time but I mean a felling like if you was to take you bike and make it go and stop as fast as you could over and over with a little grinding sound almost as if lunging forward like in gear then out of gear "jumping and grinding "
Discussion Starter · #8 ·
Yeah it does I was just wondering because with the clutch out of the mix I can ride in first all day no noise at all that is what leads me to thank the clutch but I just did not want to get taken to school when I went to the shop if you know what i mean
1 - 8 of 8 Posts
