had to change brake light switch, filled reservoir with fluid bled brakes no bubbles, pedal would hold pressure and not leak down and had brakes. Sets overnight no pedal but will pump up and hold. Don't know what else to do.
You are probably getting air into the system. My first suspect would be the brake light switch you just replaced. Did you put tape on the threads?
Did you refurbish the brakes. May just be a stuck piston that released if you didn't. Maybe?
Swamp Rat Rider
Would give the Caliper Pistons a Look See anyway ..
